Ever type a chemical formula like C6H10O5, then stop to hunt down each subscript number one at a time?
It is a tiny formatting task, but it can turn into a surprisingly tough detour when formulas show up throughout your notes, reports, or replies.
A recent question sent me looking for a smoother option.
This JavaScript Snippet lets you enter a formula the way you normally would:
C6H10O5
Then TextExpander returns:
C₆H₁₀O₅
One Snippet can handle different formulas, so you do not need to build a separate one for H2O, H2SO4, C6H10O5, or every new compound you type.
Here is how to set it up, or you can get it from our public groups found here
Create a new Snippet.
Set the Content Type to JavaScript.
Paste in the code below.
Give it an abbreviation, such as ;sub.
var formula = “%filltext:Formula%”;
var subs = {
“0”: “₀”,
“1”: “₁”,
“2”: “₂”,
“3”: “₃”,
“4”: “₄”,
“5”: “₅”,
“6”: “₆”,
“7”: “₇”,
“8”: “₈”,
“9”: “₉”
formula.replace(/[0-9]/g, function (digit) {
return subs[digit];
When you expand the Snippet, a Formula field will appear. Type your formula using regular numbers, press Enter, and TextExpander will return it with subscript digits.
JavaScript can look a little intimidating, but this one is really just a tiny translator for the numbers 0 through 9.
A small heads-up: the Snippet converts every digit you enter. It works best for a standalone formula. If you enter a full equation with a leading coefficient, that number will become a subscript too.
Try it today with one formula you use regularly and see whether it saves you a formatting detour.
Question for the community
What text containing subscripts do you find yourself typing repeatedly?
