I’m finding that my abbreviations are not being fully deleted on expansion. This is a recent problem that I’m finding in Outlook, though it may happen in other contexts. The expansion in question is an email signature (I prefer to use expansions for these rather than the built-in signature feature so I can quickly decide which signature to include based on circumstance.) I have been using the same abbreviation to expand the same thing for many years, but recently, when I type the six-character abbreviation, only the last five characters are deleted, leaving the first character just sitting there at the beginning of my signature. This happens around 8 or 9 out of every 10 times I use the snippet.
Is there any setting for this snippet that I can change to make this snippet more reliable?
TextExpander v. 8.4.8
MacOS 27.0.2
Outlook 16.113.4 (I can’t change this because of work policies.)
Thanks for reaching out! There are a couple of things I’d like to check to help narrow down what’s happening here.
First, what is the abbreviation you’re using for this Snippet, or specifically, what is the first character of the abbreviation? Outlook can treat certain characters, such as @ or /, specially, so I’m curious whether Outlook may be responding to that first character before TextExpander completes the expansion.
I’d also be curious whether you’re using New Outlook or Legacy Outlook, and whether you see the same behavior in both new messages and replies.
One quick test that would be especially helpful: could you try expanding the same Snippet about 10 times in TextEdit or Notes? If the abbreviation is consistently removed correctly there, that would help us confirm that we’re looking at something specific to how Outlook is processing the expansion.
You could also try changing the Snippet’s expansion behavior from expanding immediately to expanding after a delimiter. The additional keystroke can sometimes help in applications that are processing keystrokes at the same time as TextExpander.
If your abbreviation does begin with a character such as @ or /, another quick test would be temporarily changing it to something that uses only letters and seeing whether the behavior continues.
If you’re able to reproduce the same issue outside of Outlook, or if none of these tests make a difference, please reach out to us at support@textexpander.com. We can collect some additional information from your Mac and take a closer look at what’s happening.
Thanks for checking those details! Since the abbreviation contains only letters, and you’re not seeing the same behavior in other applications, I’m curious whether something within New Outlook may be interfering with the expansion.
One quick thing I’d like you to try is turning off Outlook’s text predictions:
Outlook > Settings > Spelling & Typing > Show Text Predictions
Once that’s turned off, please try the Snippet a few times and let us know if you continue to see the extra character.
If the issue continues, we’ll want to take a closer look at what’s happening during the expansion. At that point, I’d recommend reaching out to our Support team so we can gather some additional information and logs without having you post those details here in the Community.
You can reach out to us at support@textexpander.com
Two things for following up:
- I have now seen the initial character of an abbreviation not deleted in Obsidian. This abbreviation does have a delimiter (semicolon).
- I already have text predictions off in every app that offers them.
