Is it possible to have an option where, when the abbreviation is typed, a menu comes up, and then I select from the menu to invoke another snippet or expansion? This would be great for responding to emails and picking out the email template you’d like to use.
HI @MikeKline
Welcome to the TextExpander Community! We’re so glad you’re here!
Great question! You can do this today with Conditional Sections! ![]()
Conditional Sections let you put several versions of a message inside one snippet. When you type the abbreviation, a fill-in window pops up with a dropdown, you pick the version you want, and only that content expands. You can even embed your existing snippets inside each choice, so your current email templates can stay just as they are.
Here’s how to set it up for email templates:
- Create a new snippet and give it an easy abbreviation, like
;reply. - In the editing bar, select the Fill-ins button and choose Conditional Section.
- Add a branch for each template using the + icon, then name each one.
- Inside each branch, add that template’s text, or use Insert Snippet to embed the template snippet you already have.
- Give it a try!
A couple of quick notes:
- Conditional Sections are available on all paid plans.
- Want to see some already made?
- Subscribe to our public Conditional Sections examples group and poke around.
- For a quick overview, check out our community post, One Snippet, every version: meet Conditional Sections.
One more option if you’d rather search instead of building a menu: Inline Search lets you pull up any snippet right where you’re typing. Press Command + / on Mac, Control + / on Windows, or Control + Period in Chrome, then type part of the template’s name.
Hope that helps! Let us know how it goes. ![]()
-Nick
