Hi Karl,
Currently, the public App Store release of TextExpander for iOS does not show your snippet library, or have the ability to create and edit snippets.
To use the TextExpander keyboard on your iPad or iPhone, you will select the Globe icon on your keyboard - much like you would do when switching to the Emoji keyboard. You would select the Globe again until you see the TextExpander logo on the keyboard (an orange stylized ’t’). Once you see the TextExpander logo, you will be able to type your Snippet abbreviations on the keyboard and have them expand.
Here’s a clip showing how to switch into the TextExpander Keyboard, so that typing triggers your snippets: https://share.zight.com/019ff77e-f11a-7cde-b0db-dada569c13be
You can also search for any snippet by using the Magnifying Glass icon, located in the upper-left corner of the TextExpander on-screen keyboard. You can search by abbreviation, label, or contents of a snippet; just like using Inline Search with the desktop TextExpander app.
In the meantime, we do have a new beta version of TextExpander for iOS available (8.5), if you’d like to give it a try. This new beta version includes a Snippet Library viewer, and the ability to create/edit your snippets. I don’t yet know an exact timeframe for this to be published into the App Store.
I do recommend removing and deleting the App Store version of TextExpander for iOS before installing the beta version. This will help reduce any potential conflicts. If you change your mind, you can always delete the beta version, and re-install the public App Store release at any time.
To get started:
- Navigate to https://testflight.apple.com/join/RYmRh7r1 on your iOS/iPadOS device
- Install TestFlight, which will allow you to install our TextExpander Keyboard Beta.
Quick tips:
-Once you’ve downloaded TestFlight, go back and select the link above, it will automatically take you to the TextExpander Beta download page.
-If you are seeing a prompt to enter a code, please cancel that prompt, minimize TestFlight, then click on the link above and this should connect you to the beta.
