MCP Use Case: Help New Hires Understand Shared Snippet Groups Faster
As an admin, you may know exactly why each shared Snippet Group exists.
The new hire opening it for the first time? Not so much.
They may be wondering:
What is this group for?
Which Snippets should I use first?
Is this the current approved wording?
Shared Snippet Groups can be incredibly helpful for onboarding, but only if new teammates understand how to use them.
That’s where the TextExpander MCP Server can help.
With MCP, supported AI assistants can help admins work with Snippet libraries through plain-language requests. Getting started is easy. You don’t need to be technically inclined, and you’ll be done in about 5 minutes! Check out our TextExpander MCP Server Getting Started Guide to get going
One useful admin workflow is asking your AI assistant to review a shared Snippet Group and draft a short “how to use this” guide for new hires.
For example, you might ask:
“Review this Snippet Group and draft a short new-hire guide explaining what it’s for, when to use it, what naming patterns you notice, and which Snippets look most important for someone just getting started.”
A guide like this could help new hires understand things like:
Who to ask if something needs to be updated
Which workflow Snippets support
How the group fits into their day-to-day work
Which Snippets are most commonly used
A few admin tips before trying this:
Start with one high-value Snippet Group
Ask for a short guide that a new hire can skim quickly
Review the guide before sharing it
Add any team context the AI assistant would not know
Update the guide when the Snippet Group changes
:bullseye:The goal is not to create a giant manual. The goal is to give new teammates a friendly map so they can start using shared Snippets with confidence.
One final tip to help new users get started is using in-line search: Check it out here
Question for the community:
What advice do you have for users who are new to using TextExpander?
