We’ve received reports from some Mac users experiencing issues with Snippets expanding in Google Chrome following the release of Chrome 155. We know how frustrating it can be when Snippets don’t work as expected, especially when you’re relying on TextExpander to keep your work moving.
Our Engineering team has investigated the issue and confirmed that a bug introduced in Chrome 155 on macOS can interfere with TextExpander’s ability to insert Snippet content into Chrome. We’ve also determined that this issue can’t be resolved through a change to the TextExpander desktop application alone.
What we know
The underlying Chrome bug has already been fixed in the Chrome 157 Canary development branch. At this time, however, that fix has not been brought back to Chrome 155 or the Chrome 156 Beta.
Based on the current Chrome development builds, we expect this issue to be resolved once Chrome’s fix reaches a stable release.
Workarounds
In the meantime, affected Mac users can try one of the following:
Turn off Restore Clipboard
- Open TextExpander.
- Go to Preferences > Expansion.
- Turn off Restore Clipboard.
This has been successful in our testing and is the simplest workaround if you’d like to continue using the TextExpander desktop application with Chrome.
Use the TextExpander Chrome extension instead of desktop expansion in Chrome.
Temporarily use another browser until the Chrome fix becomes available in a stable release.
We’ll continue monitoring Chrome releases and update this post as we learn more and the fix makes its way to a stable version. Thanks for your patience while this is being addressed. We know how important it is to have Snippets working reliably, and we want to help you get back to your usual workflow. Please let us know if you have questions or need help! ![]()
