Working on Remote Windows PC from causes problems
When I work from home on my iMac, which has TextExpander installed, I use Windows App to remote into my work PC running Windows 11, which also has TE installed. Sometimes nothing expands, sometimes I just get the letter ‘v’ (presumably from TE pasting). In other words performance is very iffy. I have tried disabling expansion on one machine while leaving it enabled on the other but that doesn’t appear to work.
Is anyone else trying to do this? If so, how have you gotten around this problem? Or are you even having this issue?
Any suggesions?
Hi @KenGranger I have a similar setup for remote desktop from my Mac to Windows machines.
What works for me is I set my preferences in TextExpander on my Mac to NOT expand into the Windows App. That way it leaves the expansions completely up to the TextExpander client installed on the remote Windows machine.
Thanks, Scott. I wouldn’t exactly swear to it but I THINK I tried that. I’ll try it again just to make sure, and will let you know!
I love the Conditional macro and am really finding it useful. Plus, I just tried using the Delay in some email templates in classic Outlook and that has helped a bunch. I was having trouble with some of the text getting dropped. (I want to like the new Outlook but…) :wink:
Finally getting back to this after not working from home for a few days. I apparently had done something wrong before, but I believe it’s working ‘as advertised’. Thanks for the suggestion/reminder.
