This is the second entry in our series on Fill-ins. Be sure to check out our post on Single Line Fields.
The Multi Line Field settings are identical to Single Line Field, with one exception: You can also specify the default display height of the fill-in. Again, this is purely cosmetic.
After expanding a Snippet with a Multi Line Field, you can click and drag on the field’s draft handle to change its size and shape. You can also adjust the Width and Height settings to improve the aesthetics.
Here’s a video demonstrating how they work:
