Roll the dice with TextExpander!
Here’s a fun Snippet to try, especially if you like board games, and it’s a great way to get your feet wet with scripting. Create a Snippet with JavaScript as the Content Type, and put this code into the content field:
// Function to generate a random number between 1 and 20
function getRandomNumber(min, max) {
  return Math.floor(Math.random() * (max - min + 1)) + min;
// Generate the random number and output it
getRandomNumber(1, 20);
This simulates rolling a 20-sided die by generation a random number from 1-20. I set my abbreviation for this Snippet to ;d20.
You can change the 20 to another number to emulate another die. For instance, change 20 to 6 and it behaves like a traditional six-sided die.
This is so cool and fun, @josh.centers! Rolling for +20 on productivity today lol :crossed_fingers:
Shouldn’t the abbreviation be something about roll for initiative? ;rfi
You could totally create different Snippets for different kinds of rolls. For instance, if you have a +2 bonus to initiative, you could bake in that math in a separate Snippet:
// Function to generate a random number between 1 and 20, with a +2 modifier
  return Math.floor(Math.random() * (max - min + 1)) + min + 2;
You can play with these if you’re subscribed to the Community Snippets Public Group by expanding com.d20 and com.rfi.
