Em dashes are one of the most underappreciated types of punctuation. They do so much, but few were aware of them—until the advent of ChatGPT. Unfortunately for us lovers of the em-dash, ChatGPT frequently uses them, so their usage is now often seen as a sign that you outsourced your writing to ChatGPT.
That’s a shame because we shouldn’t let a machine dictate how we write or prevent us from using the English language to its fullest.
Em Dash Uses
The em dash is a flexible form of punctuation inside sentences. Here are the ways you can use it:
- To set off extra information or emphasis: The hike was challenging—steeper than we expected—but the view at the top was worth it.
- To replace parentheses for a more dramatic pause: My brother—who never cooks—suddenly made a three-course meal.
- To indicate a sudden break or interruption in thought: I was about to explain when—well, you wouldn’t believe what happened next.
- To highlight an appositive (a restatement or explanation): Three states—Tennessee, Kentucky, and Alabama—will see the greatest impact from the storm.
- To emphasize a conclusion: He only wanted one thing—victory.
How to Type an Em Dash on Mac
The Mac keyboard shortcut for an em dash is Option-Shift-- (hyphen).
How to Type an Em Dash in Windows
Typing an em dash in Windows is a bit more complex. If you have a numpad, you can hold down the Alt key and type 0151 on the numpad. If you don’t have a numpad, press Windows + . (period) to bring up the emoji keyboard, click the Symbols tab and click the em dash (longest dash).
How to Type an Em Dash on a Chromebook
You’ll want to stretch your fingers first! Press and hold Ctrl + Shift + U. While holding those keys, type 2014. Then press Enter or the spacebar to insert an em dash.
How to Type an Em Dash with TextExpander
TextExpander makes this a heck of a lot simpler. You can create a Snippet with an abbreviation like ;emdash and use it on a Mac, a Windows PC, or a Chromebook—one unified shortcut across all platforms.
I’ve made this even simpler for you: Subscribe to the Community Snippets Public Group and expand com.em.
Here’s a video of such a Snippet in action:
Em Dash vs. En Dash vs. Hyphen
There’s three kinds of line punctuation, and they can be confusing. Here’s a quick guide on the differences:
- A hypen (-) is the shortest and is most often used to combine words. (well-known)
- The em dash (—) is the longest and we discussed it above.
- The en dash (–) sits in the middle and it’s usually used for indicating ranges, like in years. (1924–1976)
