I am sure this is possible and it is just a coding thing I don’t know but how can I add a superscript or subscript for chemical formulas into a snippet? for example Cl2
Hi Amanda, this has been asked before and this is currently the best way to achieve it that I’m aware of:
I would be happy to help you create the Snippet you need.
Hi @AmandaEdson ,
I saw your question and I thought a visual might be helpful in addition to the community post.
You can see an example of how to do this in this video
https://share.zight.com/YEuYKnp1
While the example is different the concept and steps are the same.
If you still need a hand don’t hesitate to reach out to us at support@textexpander.com where you can get a much faster response ![]()
I hope this helps, and I hope you have a great day!
-Nick
@NickKreiter thanks so much! That helps a lot because I am not adept at coding but have picked up bits and pieces which makes it even harder since I don’t know what I don’t know
Also I am going to play around because editing in word allows me to do a lot of the things I have been wishing for that have been tricky. I am excited to give it a try!
I’m so glad to hear this helped!
Let us know if you get stuck ![]()
Hi @AmandaEdson,
I remembered helping you here a little while back and I just created a new snippet that I think will really help you out.
This JavaScript Snippet will allow you to type something like H2SO4, and it’ll expand as H₂SO₄. One snippet handles any compound this way, so you won’t need to build one per formula.
Here’s what to do ![]()
- Create a new snippet and set the content type to JavaScript.
- Click the Fill-ins button in the editing bar → insert a Single Line Field → name it
Formula. - Paste this script:
var formula = "%fill:Formula%";
var subs = {"0":"₀","1":"₁","2":"₂","3":"₃","4":"₄","5":"₅","6":"₆","7":"₇","8":"₈","9":"₉"};
formula.replace(/[0-9]/g, function(d){ return subs[d]; });
- Give it an abbreviation, like
;sub.
When you expand it, a box will pop up asking for “Formula” just type out what you need and just like that, you’re ready to go!
Let me know if you need any help
- NIck
@NickKreiter I just got back from leave so I had missed this, but this is so awesome thanks!!
