One of my favorite Snippets when utilizing AI code editors and assistants
I’ve found when uzing AI coding editors like Cursor AI, v0, or Replit, I’m often feeding back to the model log files or error messages. Sometimes I can directly reference them, but often I’m put in the position of needing to copy the errors and give them back to the model.
I’ve created a Snippet that both utilizes the content on the clipboard, as well as can hit “return” for me automatically, making this repetitive process much easier. Super simple, but brings me quite a bit of joy. :slight_smile:
I love this! I am wondering I usually use VBScript with error reporting in a Windows Script but it does not seem to allow copy and paste, it it different for those programs? What is the Clipboard snippet composed of?
Hi Amanda, I’m not sure about the VBScript environment you are using. The “clipboard” fill-in in a Snippet is a cool way to insert whatever is currently on the computer’s clipboard into the Snippet in that particular location. You can find details on this Learning Center page.
J.D.
