Here’s a handy Snippet for incident reports, which you can adapt to your own needs. You can try this Snippet by subscribing to the Community Snippets Public Group and expanding com.incident.
What makes this Snippet unique is it uses nested Optional Sections. For both the password and network blocks, none of the options will expand unless the top entry is selected. For instance, if you check “Password failed” but not “Reset Password?”, that part won’t expand. This lets Optional Sections serve as a kind of branching logic so you only expand what you need.
Here’s how it looks in the Snippet editor.
