I used Microsoft 360.
I use a table in several of my emails. I use TE to insert the table into the emails. But the tables cells have very little width and I have to expand the width of the columns manually every time. Is there a way to set the width of columns in the Snippet so I don’t have to readjust manually every time?
Hi @DavidSimonelli - while there isn’t an exact way to set the width, you can try this HTML trick! Let us know if it works.
