If like me you’ve had to do a fair bit of data wrangling in your lifetime, chances are you get given csv files that have the column headers missing. Now, if this happens on a regular basis for similarly structured data, scrabbling around to find the appropriate headers in another Excel file or Google Sheet can become a real chore.
As Textexpander can “tab across,” the cells, entering the headers as it goes, it makes sense to get Textexpander to do this. It makes even more sense to use a formula to magically create the text we need to drop into a snippet, especially if there are many headers. Here is that formula…
Google Sheets
=JOIN("%key:tab%", FILTER(INDIRECT("A1:" & ADDRESS(1, COLUMN()-1)), INDIRECT("A1:" & ADDRESS(1, COLUMN()-1))<>""))
Microsoft Excel
=TEXTJOIN("%key:tab%", TRUE, FILTER(A1:INDEX(1:1, COLUMN()-1), A1:INDEX(1:1, COLUMN()-1)<>""))
Now, if we have say, “Beef”, “Chicken”, “Pork”, in cells A1, B1 and C1 respectively, dropping the appropriate formula into D1, will output…
Beef%key:tab%Chicken%key:tab%Pork
In that output, you will see we have the text %key:tab% which, back in the day, you could manually type into Textexpander to denote a press of tab key was required.
To get our Textexpander snippet to work as required, we have to jump through a couple of hoops…
- Paste the string,
Beef%key:tab%Chicken%key:tab%Porkinto a snippet with Content Type = Plain Text - Next, switch the Content Type to JavaScript
- Expand the snippet via your abbreviation, and you’ll get
JavaScript Error: SyntaxError - Unexpected token ':' - Switch the Content Type of your snippet back to Plain Text and you’ll now see our column headers are delimited by the Tab lozenges
The snippet can now be used and will expand across our headings as required. It would obviously be great if we didn’t have to go through the merry dance to coerce the Tabs. But of course, if you only have a few columns for the snippet, you can manually build the snippet using Keyboard macros > Tab.
