It would be nice if the copy to clickboard option had ability to choose when.
For example, there may be sometimes where my situation would be that I need to copy something to the clipboard, but do not want that information to be public or go anywhere other than my own local. It might be credit card information. It might be someone’s name and phone number. It might be a Social Security number.
Also one really big thing if it’s at all possible and I’ve mentioned it before, but I think it would help a lot of people
The first thing is, is there any way to turn off the closing and finishing up a snippet when using single line fill-in if you hit the return you’re done
It would be much better to have to specifically indicate that you’re done rather than automatically under any circumstances, closing only because a return key was hit sometimes by accident
Also, since I type pretty fast, I’m so automatically if it’s a new paragraph I hit return and I’m already halfway into the next paragraph but this really interferes with speed
The next thing that would be good would be after the snippet has been completely filled in, that the information is saved, and the next time you want to open that snippet, it keeps all of the data in the snippet and allows you to change or update any changes of information For example, most patients are on 3 to 4 medications, and at least three of those are usually exactly the same each time
Or a patient may have 5 to 6 medical problems. Those aren’t going away they may improve, but most medical conditions are not cured only surgeons, OB/GYN/pregnancy, and infections are cured.
Guess would reduce having to completely redo all of the different sections. It’s not practical to go back and just copy and paste the previous final output because it needs to be in specific sections of the chart.
If it’s possible to do this, you would also want to be able to label it in such a way that you can find it and there would need to at least be a six or seven digit code
If these two areas were addressed, I might even want to get a part-time gig as a text expander rep going around the doctors offices and explaining to them why they should be using text expander.
We could work out the details on commission later.LOL
