Auto-select optional section based on date fill-in?
I have about 6 complex sales email snippets that all share the same basic architecture: two optional sections (“peak” and “off-peak”) that control different blocks of text scattered throughout each snippet, along with nested snippets. These have been refined over a long time and I really don’t want to rearchitect them.
Each snippet also has a date fill-in field (a text field I fill in formatted mm-dd-yy). The rule for which optional section should be selected is simple:
  • Peak: Saturday, April through October
  • Off-Peak: Everything else
Right now I manually check the correct optional section checkbox every time. The problem is twofold:
  1. If I check the wrong one, the wrong pricing and copy goes out.
  2. If I forget to check either one, large chunks of the email just don’t appear in the output. I don’t notice until I’ve already filled in all the other fields (customer names, venue, dates, greeting, etc.) and the snippet has expanded. At that point I have to start over and re-enter everything. It’s a real time sink.
What I’m looking for: A way to auto-select the correct optional section (peak or off-peak) based on the date I enter in the fill-in field. Ideally something I can apply across all 6 snippets without duplicating them or converting all the optional sections to JavaScript conditionals.
I’m on TextExpander 8.4.2 on Mac. Is there a way to programmatically control optional section state from a JavaScript or shell script macro? Or another approach I’m not seeing that preserves the current snippet structure?
Appreciate any ideas.
Paul
If I understand correctly, Are you filling in the date because it is being used in various spots? It sounds to me that it would be much easier just to have 2 versions of the snippet and you simply select if you want peak or off peak. I may be misunderstanding your set up.
Get ChatGPT or Claude to help you write some apple-script to select depending on date, take that portion of code and edit it into your existing snip. To get %fill… Looking code to change to bubbles, switch between text and applescript and back after making any minor edit [like adding and deleting a space] which it needs to understand edit complete
TextExpander staff: is there a way to use non-printing “return” characters to make snippet readable but not expand the spaces and returns surrounding not selected “optional sections”
Hi Alex,
Yes, the date is used in various spots throughout the snippet. But there’s more to it than just peak vs off-peak.
Each snippet has around 20+ fill-in fields (customer name, spouse name, venue, greeting style, event type, etc.) plus about 15 other optional sections beyond peak/off-peak (venue-specific content, greeting variations, contact info toggles, and more). And peak/off-peak aren’t just one block of text each – they each control multiple sections scattered throughout the snippet that change pricing, copy, and other details in different places. I go through the fill-in panel, enter all the details, check the relevant options, and the snippet builds a complete customized email.
Having two versions of each snippet would mean maintaining 12 snippets instead of 6, and every time I update the copy or add a venue or tweak the structure, I’d need to do it in two places. With all the nested snippets involved, that gets fragile fast.
The peak/off-peak logic is the one part that’s fully deterministic – it’s just a function of the date I’m already entering. So ideally I’d love a way to have TextExpander auto-check the right optional section based on that date input, rather than duplicating everything.
Got it. I think it would be doable through JavaScript but would be hard to make suggestions or test without seeing your snippet/options.
