Ever start setting up TextExpander for a new team and stare at an empty Snippet Group, wondering where to begin?
Blank libraries can feel a little intimidating. You know your team repeats certain replies, links, and workflows, but turning all of that into a useful Snippet Group can be the hard part.
That’s where the TextExpander MCP Server can help.
With MCP, supported AI assistants can help you work with your Snippet library through plain-language requests. Getting started is easy. You don’t need to be technically inclined, and you’ll be done in about 5 minutes! Check out our TextExpander MCP Server Getting Started Guide to get going.
Once connected, you can ask for help creating a starter Snippet Group for a specific role, team, or workflow.
For example, you might ask:
“Create a starter Snippet Group for a healthcare admin team with 10 common replies for scheduling, intake forms, insurance questions, referral updates, prescription refill requests, and follow-up instructions. Include friendly patient-facing wording, abbreviations, and labels.”
You could also create starter libraries for teams like:
Recruiting
Billing
Sales
Support
A starter library does not need to be perfect. It just gives your team a practical first draft of replies people can review, edit, and start using.
You don’t have to start from zero, either. TextExpander public groups can be a helpful source of inspiration when you’re building your first library. You can browse examples, borrow structure, and get ideas for common snippets your team may want to customize.
You can use public groups on their own, or pair them with MCP by asking your AI assistant to help adapt a starter idea for your team’s specific workflow, tone, and naming style.
Check out our Public Groups page
Medical professionals will want to check out Dr. Ries’s public snippet library
A few tips before trying this:
Start with one team or workflow
Ask for a small starter set first
Confirm links, policies, or process details
Customize the tone so it sounds like your team
Add clear labels and abbreviations so people can find what they need
The goal is not to have AI build your final library in one step. The goal is to get past the blank-page moment and create a useful starting point your team can shape together.
To try this, pick one workflow your team repeats often and ask your AI assistant to suggest a starter Snippet Group for it.
Questions for the community:
What team or workflow would you build a starter Snippet library for first?
What advice do you have for someone just starting with TextExpander?
