Curious about the TextExpander MCP Server, but not totally sure where to begin?
You’re not alone. MCP can sound a little like someone dropped a bowl of alphabet soup into your workflow, but the concept is luckily simple. It lets supported AI assistants work with your TextExpander Snippet library through conversation.
This week’s focus: using the TextExpander MCP Server in a practical, low-stress way.
A good first step is to start with something simple, like asking your AI assistant to:
List your Snippet Groups
Show the Snippets in one specific group
Create a new Snippet Group
Turn a common message into a Snippet
Suggest abbreviations for a few replies you use often
Help clean up or organize an existing group
For example, you might try a prompt like:
“Create a Snippet Group called Customer Support and add three Snippets: one for a greeting, one for asking for more details, and one for a friendly closing.”
-Or-
“Show me the Snippets in my Email Templates group and suggest which ones could use clearer labels or abbreviations.”
A few tips before you dive in:
Start with one Snippet Group instead of your whole library
Be specific about the goal, abbreviation style, and tone you want
Review anything before you use it with customers or teammates
Use clear names for new groups so future-you does not have to become a detective
For team Snippets, make sure the right people should be creating or editing shared content
The goal isn’t to hand your whole library to AI and hope for the best. The goal is to use it as a helpful assistant for building, finding, and improving Snippets faster.
To help others learn, reply with:
Which AI assistant you’re using
What you’re trying to do with the MCP Server
The prompt you tried, if you’re comfortable sharing it
What worked well
Where you got stuck or had questions
