Hi All,
I sometimes have the issue that snippets do not populate in iphone even though:
-They work on my MAC
-I have restarted the iphone
-I have closed and then opened both the software I am using and also TE
-I have checked the spelling on the iphone
-I have made sure the phone TE app is updated with all my latest snippets
-I have, on my MAC and also on my phone, logged into TE and changed a snippet by at least one character and saved this change (in some sort of pathetic attempt to ‘restart the servers’!)
-I meditated for two minutes to ‘manifest’ TE working all of a sudden.
Does anyone have a hack that I have not considered please?!
Nic
I’ve just taken a look at your account, and I noticed you’re using our discontinued version of the iOS app. We’ve made some updates and have a newer version in beta that has more reliable expansion on iOS. I do want to note, though, that there are still a few limitations due to iOS restrictions that we’re still working through. For example, snippets with clickable URLs still aren’t expanding.
If you’d like to try the newer version to see if you have more luck:
Install TestFlight, which will allow you to install our TextExpander Keyboard Beta.
TestFlight Redemption Code:
vKrjNFUr
Quick tips:
Once you’ve downloaded TestFlight, go back and select the link above, it will automatically take you to the TextExpander Beta.
If you are seeing a prompt to enter a code, please cancel that prompt, minimize TestFlight, then click on the link above and this should connect you to the beta.
Please let me know if that helps. I’m happy to answer any questions you might have!
@TextExpander Is there a new beta for the iphone app? I followed a post from April with a Text flight code but Test Flight isn’t accepting the code at all. Perhaps it’s expired?
If you still see a prompt to enter a code, please cancel that prompt, minimize TestFlight, then click on the link above and this should connect you to the beta.
Yes. Inexplicably, it’s been in beta for several years. Textexpander used to have an SDK, which meant that, if developers incorporated it, you could expand snippets “natively,” within that app. That was the case with Drafts for example.
This is your space to ask questions, find support, and share ideas with fellow TextExpander users and our product team. As a first step, take a moment to introduce yourself to the community.
