Since updating to TextExpander 8.6, I’ve noticed that closing the main application window also quits TextExpander entirely, preventing snippets from expanding.
In previous versions, I could close the TextExpander window using the red close button (not Command-Q or Quit), and the application would continue running in the background. This allowed me to use snippets without keeping the main window open.
With version 8.6, closing the window appears to terminate the application completely, and snippet expansion stops working until I relaunch it.
I’m running macOS 27.2.1.
Is this an intentional change in behavior or a bug introduced in version 8.6? If it’s a bug, what’s the best way to report it? Is this forum the appropriate place, or is there a dedicated bug-reporting channel?
I closed my window, I am on Mac 27.2.1 as well. I closed the window, on the bottom it still show app is active and can open snippets. Maybe reboot!
Reboot is the first thing I tried. Didn’t fix it though, unfortunately.
same here: TE still works with closed window.
macOS 27.2.1 (26B131)
Hmm… I’ll have to try a complete uninstall and reinstall.
An uninstall and fresh reinstall appears to have resolved the issue.
Hi @christian,
I hope your Thursday is going well!
I’m so sorry 8.6 had TextExpander quitting every time you closed the window!
This wasn’t an intentional change. Closing the main window should leave TextExpander running in the background so your Snippets keep expanding.
We’ve seen this happen on Mac when the “Show TextExpander in the menu bar” setting is turned off, and our team is aware of it.
If it ever comes back, here’s a quick check:
- Open TextExpander and go to Preferences > Appearance.
- Make sure “Show TextExpander in the menu bar” is turned on.
- If you’d rather not see the icon, you can tuck it behind the macOS menu bar overflow instead. TextExpander keeps running that way.
The forum is a great place to ask questions and swap tips with other users!
For bugs, the best way to report them is to email us at support@textexpander.com. That way we can look at your logs and get the details to the right people.
Thank you @LoreeChristianson and @Thomas_U for jumping in to compare notes too!
If anything else comes up, don’t hesitate to reach out! We’re here to help!
-Nick
Thanks, @NickKreiter, for the information! I was reluctant to upgrade on my home machine, but I’ve since done so, and everything is working normally there. No un/re-install needed there.
Thanks again!
