Is there a way to permanently collapse a snippet. For example, I have a closing that I use for emails that i would like to be able to select or deselect various things. If I use “show at top” I cannot select certain things but if i don’t use show at top my signature is so long that i end up needing to scroll. Is there a show xyz at top or some way for me to still collapse down the signature field.
vsHi Amanda,
I think a PopUp Menu for some of those lower options could be helpful instead of Optional Sections. The PopUp Menu is in the Fill-Ins section as well.
Here’s are screenshots of what the Fill In Window will look like:
That worked out much better thanks for the suggestion!
