Why Didn’t My Snippet Expand? Start with the basics
Ever type your abbreviation, wait for the magic, and then… nothing?
Before assuming your snippet has packed a tiny suitcase and left town, there are a few simple things worth checking first.
This week’s focus: snippets that don’t expand.
When a snippet doesn’t expand, start by checking:
  • Is TextExpander running?
  • Is expansion turned on?
  • Are you typing the abbreviation exactly as it’s saved?
  • Does the snippet work in other apps?
  • Is it happening with one snippet or all snippets?
  • Are you using a regular snippet or a fill-in snippet?
These details can help narrow down whether the issue is with TextExpander settings, a specific app, the abbreviation, or the snippet itself.
To help troubleshoot, reply with:
  • Where it’s happening: Mac, Windows, Chrome, iOS, etc.
  • Whether it happens everywhere or only in one app
  • The abbreviation you’re trying to use
  • Whether it’s one snippet or multiple snippets
  • Whether it is a regular snippet or a fill-in
We’ll help you narrow it down and share fixes others can use too.
Question for the community:
What’s the first thing you check when a snippet doesn’t expand?
I usually go to File > Disable expansion and then turn expansion off and then Enable expansion again it seems to fix it most often
