Expanding Snippets on iOS / iPadOS
Now that the TextExpander for iOS / iPadOS app live in the App Store, you can expand your Snippets across your iPhone or iPad!
-If you haven’t already, you can download and install the TextExpander iOS app directly from **here.**
Once you have the app installed, signed-in and setup, to use the TextExpander keyboard on your iPad or iPhone, you will select the Globe icon on your keyboard.
It’s just like like you would do when switching to the Emoji keyboard. You will then select the Globe again until you see the TextExpander logo on the keyboard (an orange stylized ’t’ on the spacebar). Once you see the TextExpander logo on the spacebar, you will be able to type your Snippet abbreviations on the keyboard and have them expand.
*Tip - You can tap the magnifying glass icon in the upper-left corner of the keyboard to use Inline Search, where you can search for your desired snippet.
To see snippets expanding in action on iOS, please watch this video clip!
Are you excited for TextExpander on iOS? Let us know!
This is a good development.
I have a problem using text expander with an external keyboard on the iPad and iPhone. This is because the snippet expansion is only enabled with a on-screen keyboard . So I suggest maybe enabling a textbox on browser, login through textexpander.com.
