How do you use TE to send a down arrow keystroke. Tried using the Cursor Macro to insert a down arrow but it only types in 2s, doesn’t actually send a down arrow keystroke.
Hi, @MichaelM, does your keyboard have a Num Lock key and is it on?
Yes to both questions.
That may be causing it. Try turning off NumLock and expanding it.
Yep, that solved the problem. It would be nice to be able to send those key strokes but have NUMLOCK still be on.
Glad it worked, Michael. I’ve alerted the product team to your feedback.
Hi Michael, This is a great enhancement, ability to send the key strokes with NumLock on. I am sure, it would be valuable to others ![]()
We’ve logged this as a feature request. Thank you for the great suggestion! Keep them coming! ![]()
